by squeek360 » 07 Oct 2001 22:30
definitely not easy dave ; however , there are 2 different versions of the 4 speed auto used in newer trucks , one is based on the 904 and one on the 727. the technical chrysler designations are "A 500" for the 904 based trans and "A 518" for the 727 based trans. I should point out however that upon further research , I found out that the 518 has a non lockup converter ; where as , the 500 has a lockup converter. but as you stated , this is no simple task requiring major mod's (nothing I would consider doing espicially given the increasing rarity of the e body)anyway , I thought info on as even a modified challenger is a sweet machine. as well , both trans assemblies can be ordered directly from mopar performance part #'s P5249165 for the 500(904) , and P5249166 for the 518 (727))
