Kickdown to the carb
Postby Hans » 17 Aug 2001 6:53
Can anybody tell me how the kickdown is mounted to the carburator. It's a 340 engine with an edelbrock carb and a 727 transmission. I'm asking this cause I just put in the engine again and fired it up yesterday but I don't have a kickdown at the moment. So if anybody could post a picture of how it should be please ...
Hans
Postby dave-r » 17 Aug 2001 9:02
Which type of linkage is it? Is it the kind that has an adjustable rod from the carb to a swivel on the throttle cable mount and then a vertical adjustable rod to another swivel on the trans with a third non-adjustable rod going to the lever on the trans?
Don't drive the car without a kickdown lever or you will damage the trans.
SEE ALSO 'Adjusting the Kickdown Lever'.
Postby dave-r » 17 Aug 2001 9:06
Or did you just want to know how it fits onto the carb itself?
Postby dave-r » 17 Aug 2001 13:35
Postby hans » 27 Aug 2001 5:17
Thanks Dave, but...
Your picture doesn't seem to be the same as the linkage I have. I will try to make/scan a pic of the linkage I have. It's not complete what I have, but I just don't know what I'm missing.
hans
Postby Douglas » 27 Aug 2001 14:35
When I got my Challenger it was in pieces. I had no idea what the kick down was like when the car was original. I am running 1970, 340 with a 727 trans and Thermoquad. What ended up working for me was a solid piece rod that rests in a "U" grove bracket near where the pivot is as in the picture above. My 318's have the pivot and two piece rods. The Challenger kick down came out of a 318 Dodge van. There was plenty of firewall room for the one piece rod. It works just fine but I doubt it was originally set up that way.
Douglas
Postby dave-r » 27 Aug 2001 20:16
Notice mine has a metal sleeve half way down each half of the linkage.
That was because when I switched to a six pack i had to lengthen the vertical piece to the trans and shorten the bit to the carb.
I will scan some drawings of the different types shortly for you mate.
Postby Guest » 27 Aug 2001 23:12
Here are a couple of scans.
This is the linkage I have.
Here is the one rod system.
Guest
Postby Hans » 28 Aug 2001 5:34
Thanks Dave, now i know how it should be. I have the setup showed in scan two. I only miss the throttle rod and one spring. So I could make it complete within this week or something. Thanks again.
Hans
