 by Ross Williams (Tx70challe » 18 Aug 2003 5:12
			Well heres my current situation, 318/w a 904 trans coupled with a 741 rear with open 3.23 on 14 inch wheels. My current plans are to go with a 360/w a 727 trans coupled to a...? My understanding of the 8.75 rearend is that theres 3 different carriers for it, the light duty '741, and then the stronger '742 and the '489's. I thought it was possible to swap between the carriers as long as you swap the corresponding yoke respective to each trans (for ex. the 7260 UJ from the 904 for the 7290 UJ for the 727). Am I forgetting axle splines here or is this non-relavent? To make a confusing question a little more clear - with my current setup can I swap to a '742 or '489 with the 904/318 and still use it when I upgrade to my 360/727 setup? Please forgive my ignornace in the matter! Cheers.
