				Band adjustment
05 Aug 2001 17:46by Lars
				Instructions for band adjustment involve tightening to a defined torque and then releasing 1 - 2 turns. How does tighter/looser adjustment affect shifting? Thanks for answers!
				Band adjustment
06 Aug 2001 20:14by dave-r
				I had a look in a manual but have not found any definate answers to this. I think if it is too tight they will drag and overheat/burn/wear out.
Less likely (depending on which band was effected) I think it might fail to change up or stick in reverse or something like that. But they would have to be very tight to do that.
Too loose and I guess it might fail to change up or down correctly or late. Maybe slip on the 1-2 shift. Take a longer time to kick down or something.
Just guesses. I would get it as close to the correct spec as possible if I was you. I can't see there being any advantage to a tighter or looser spec if that was what you were wondering.
I think there is some tolerance built in though so as long as it is not too far out either way each band will still work as it should.
				Band adjustment
07 Aug 2001 11:13by Joel
				Personally, I would rather pay someone who has been trained to fix transmissions than fiddle around with my own tranny, eh?
