 by Hans Buijnink (72challeng » 20 Jul 2003 15:36
			OK, I just studied the service manual a bit.
- Centerline of the engine/trans is the oil pan rail = underside of the engine block.
- Centerline of the diff is the mounting pads of the pinion snubber = the same as housing gasket minus 90degree. Using this is more calculating but there's more 'room' to measure.
- Centerline of the shaft is duhh...
The angle between the engine and driveshaft have to be between 177&180 or 0&3 degree depending how you look at it. (in fact it's same) and the same thing for the angle between the driveshaft and diff. Then both angles have to be as close to eachother as possible. Just like the fig. in the link. From your earlier message (see link) I understand if it's possible go for 2degree for the smoothest ride.
I'll take an anglefinder from work this week and check the whole thing. I will then measure all the different angles in contraction with, please help me out here, the "waterline??". Them with some calculating I hope to be able to set it all as it should by shimming the trans as I don't want to go the "shim the rear axle" route. I'll keep it all posted.
