Hi My Name is Ron and I live in Caledonia Ontario Canada. I have restored (restoring) a 72 Challenger with a 440 and 727 tranny. When rebuilding the transmission I had a reverse manual valve body installed therefore the transmission has to be shifted manually and drive is 1st, 2nd is 2nd and 3rd is 1st gear pulling back on the shifter instead of pushing forward to up-shift.
My problem/question is that when up-shifting there is no lock between gears and it is quite easy to go from 1st to 3rd. Is it possible to make a slapstick "ratchet" when both up and downshifting or do I need to go to an aftermarket shifter?
