At the end of part two I had fitted the unit in place and set the angles between the trans, driveshaft, and diff.
Since then I have re-built the diff again because I was not happy with the mesh pattern. Bad weather has prevented me getting on with the car too.
Then the next problem reared it's head.
When I came to fit the speedometer cable extension and adaptors I realised the right angled adaptor needed was the wrong part.
This is what it should look like fitted. It is the right angled adaptor fitted to the speedo drive.
....and this is the part they sent me.
This part has no square male part to be driven by the drive in the transmission. Also the female part in the other end is round and would not drive the cable.
So I 'phoned up Gear Vendors and told them I had the wrong part. The guy I spoke too took a little convincing and the language barrier did not help but eventually he understood the problem and sent me out a 'correct' part straight away at no extra charge of course.
But I still have to pay duty and other charges at this end so it cost me about $25.
This is the part he sent.
Now this part looked right. It even had the grease nipple like the one fitted above. Plus it screwed together with the other bits so I was very happy and was looking forward to fitting it tonight at long last.
BUT! It does not fit in the trans tunnel!
As you can see it is not quite the same as the one pictured fitted at the top of this page. It is longer and even though in this photo I have the transmission dropped a couple of inches you can see it is not going to fit without a fair bit of metalwork in the trans tunnel. With the trans back up in it's correct location it is even tighter.
So I am going to send Gear Vendors an e-mail tonight with a link to this thread so they can see for themselves what the problem is. Hopefully they will be in touch with a solution?
Watch this space.
