 by Dave-R (Roppa440) » 27 Mar 2003 15:01
			The oil in the diff should last years so I don't know if it is worth fitting a drain plug?
I do have a spare trans pan drain plug kit that I could use.
This is the third time I have had my axle apart in the last 10 years anyway so it hardly seems worth fitting a plug in my case at least. But I suppose now is the time if I am going to do it because the axle is in bits at the moment.
Yes Glenn you should fill it until it spills out of the filler hole (with the car level).
