 by Johannes Brudevoll (Johan » 06 Mar 2003 6:20
			Rubbermount modifications are..
The "rubber mount" (picture 4) has like I saied been modified.
If I remember correctly, I took out the metal oval containing the rubber part. Then shortened the legs on the mount, using a wise.
Last I spotweld the metaloval back to the legs.
Finally the OD ended up so close to the crossmember, that I ever so little used the angle grinder on the top of the crossmember to have it clear the OD-rib.
Does my crossmember look stock Dave img tst Pretty "shitty" welding on it,...so maybe it was modified at some stage. Remember my car was originally a 318, but had a 440 in it when I bougth it...
Well, trust YOU to give an excellent step by step mounting instuction ......
Please note,....my bolts clamping the rubber mount to the tranny, came loose over the 1'st summer,... lockwashers are recommended.....}
