 by alex » 22 Apr 2001 22:28
			If the axle is sure grip, with both rear wheels of the ground, spin one and the other will rotate the same way, if it's open the other wheel will spin the opposite way, there should be a tag on one of the carrier bolts saying something like "use limited slip diff oil only", alternativly, lift one wheel, and then try and spin it, it should not move if it is a grip diff, there is a torque figure to tell you how much force is needed to "break" the cones to test it for wear. the diff will probably be worn, but contrary to popular belief, they are repairable, if you know how.
