I came across some technical information today on the TF727. It has to do with shift kits and how they should function. So with your permission, here goes.
Many think that the harder a shift feels, the better the shift is, and how it adds to the performance and durability of the transmission. This thinking is correct, providing the stiffness that is being felt is not being caused by interferance or overlap with the gear that is being changed.
There is a great amount of overlap on the TF727 during the 2-3 shift. Overlap by the way, is the time the transmission is literally in two gears (in this case, 2nd and 3rd )at the same time. Overlap is a major contributor to band and clutch wear in the 727. This overlap is often mistaken for firmness, when in reality, it is shift stiffness. When you eliminate overlap, friction is reduced, and the result is an improvement in performance and reliability. You will find that when you eliminate the overlap condition, the 2-3 shift may feel less firm. The condition is ok, provided you have installed the shift kit correctly, and your throttle and band linkages have been set as instructed. Your aim on the TF727 should be a smooth, QUICK gear change that feels kind of loose under light throttle. This information applies mainly to street driven vehicles that have been slightly modified. Transmission that are going to see very high horsepower, and are going to be used strictly at the race track are another matter, and I don't want to get into all the tricks and high dollar modifications and parts that are in a race transmisson.
Another thing that should be pointed out, is you MUST follow the instructions in any shift kit exactly. Too many times, I've seen good valve bodies ruined because someone thought he knew more than the maker of the kit. If your not an automatic transmission mechanic, or don't have a complete understanding of the hydraulics of an automatic transmission, don't try and reinvent the kit you've purchased.
I hope this information is of some help to the group, and as I find more hints/kinks that I think the group can make use of, I'll pass it along. I've got some good information coming to help you select the CORRECT high stall converter for YOUR application in YOUR Challenger.
		 by Graham Shortreed (Transma » 28 Nov 2002 6:01
