Oh you did get back to me did you Dave?..
Can't remember having seen that mail...Ohh well.......
The overdrive;.......best fun money can buy!!!
I was practising my "rapid fire gear exchange" all summer 2001. Of cource we went to Power Big Meet in Sweden, and quite a few other places.
With my "new" (2'nd hand) P275/55R15, and my Hijackers=liftback filled to max airpressure, I managed to ruin my limitedslip. Suddenly only one tire were smoking, when doing piruettes with the car all filled up with people.
I managed to persuade my wife, to spend an afternoon getting "new" parts, on our honeymoon when passing San Francisco early this year.
I still regret using all that money (parts/work), just so that BOTH tires will be smoking next time I get the chance to use car.
2 years until next time........
OVERDRIVE details...
I've got a few pictures of how it looked after the installation....used an angle grinder on the OD to get a few more mm clearence,...and just to be on the safe side, I used the hammer on two places on the car itself.
Apart from the INSANE sound of the 440 running through the gears like a motorbike, the noise level at cruising came down A LOT. And of course,....whenever passing a car,...you can shift down twice (even 3 times..)
OOhhh what a nice sound.........
I still have'nt been able to measure the fuel consumption after the installation.....
Too many people are quite off the target, when discussing fuel consumption. There are MANY things to consider, and unless you have the correct tire size, gear-ratio, to go with your odometer, you can really be far FAR from the truth.
"The more power you have, the more you use" rule also applies.......
I've heard comments like "Those wide tires of mine are increasing the air-drag so much you will not believe the impact on the fuel consimption"......If you try to explain the difference on tire diameter,...they don't believe you......He he...
My suggestions to those of you who have a "friend" bragging of how little fuel his ride are using,......Go cruising together (in seperate cars).....fill up before you start,....and after you've finnished.......THEN COMPARE !!!
Of course,....if you want to win this little competition,...stay off the accelerator,....and make sure your tire pressure is 'up there"....
5 km to 1 litre?!?......acceptable to me !!!!
By the way,....I have a REALLY nice picture of a car-wreck I spotted in Washington State,....not a Chally,...but a MOPAR still....wanna see it?
