by Graham Shortreed (Transma » 06 Nov 2002 2:41
I work for a converter remanufacturer / transmission parts supplier. All Chrysler engines with a cast iron crank require a converter with weights on it, unless you've had the engine balanced. If your engine has a steel crank, non weighted converters are the correct way to go.
Flex plates for all Chrysler engines fall only into two types, of which there are two different models.
1st. For 12" Inch convertors, with even or uneven crank bolt patterns.
2nd. For 11" Inch convertors, with even or uneven crank bolt patterns.
The HEMI of course had its own.
On the high stall convertors we make, the convertor bolt pattern/mounting pads are made for the 11" diameter flex plate.
Nothing complicated about either item.
On high stalls, your convertor should stall approximately 500RPM over where the cam starts to make power. Therefore, if the cam starts to make power at 2600 RPM, the convertor should have a stall speed of around 3000 RPM.
We do not recommend a converter to have a stall speed higher than 2700 RPM, if the car is going to see a lot of street use. In my 71 340 Duster I used to own, with the 3.55 rear end, a 10" (3500 stall) converter was usless driving the car back and forth to work. Engine had to buzz past 3500 RPM to get past the stall speed, which meant that I drove back and forth to work in 2nd gear, and even back then with gas at only $.50 a gallon, it took a big dent out of the wallet
