				Slap-Stick Shifter Spring
10 Apr 2002 22:15by George Meier (440rtse)
				My slap-stick shifter recently began to feel sloppy and had a lot of play in it. I removed the console and found that the spring at the end of the rod opposite of the shifter was hanging loose from the bracket.I looked around on the transmission hump for a small hole or anything else to connect the other end of the spring to but came up with nothing. I'd appreciate any info. Thanks
 70 Challenger
 440 RT/SE
13 Apr 2002 3:59by Tedd Lister (Teddl)
				Lucky I have not put my console back in yet. Hope this helps.
13 Apr 2002 13:42by Tedd Lister (Teddl)
				BTW,
I found that putting a little spray grease on the pivot points really makes the shifter smooth and might prevent the problem you have.
I still have problems with the button sticking on mine, usually when shifting to first. I have to pull the handle out and back in. Anyone else have this problem?
Tedd
13 Apr 2002 13:55by Dave-R (Roppa440)
				I am not sure but is the button not supposed to stick in when pulled back to first so that you just have to hit the stick for the 1-2 shift?
14 Apr 2002 1:32by George Meier (440rtse)
				Thanks Tedd for the help. Your picture showed exactly what I needed. I don't know what could be causing your shifter button to be sticking. I appreciate the help. Thanks again.
 70 Challenger
 440 RT/SE
14 Apr 2002 14:21by Tedd Lister (Teddl)
				Its one of those occasional things and not really a priority over getting the interior in. It does have a crack near the base, maybe the looseness is causing problems.
Tedd
15 Apr 2002 3:39by Sf (Sf)
				I have a T handle that I bought I that Cannot use.
				slap stick shifter spring
21 Jan 2009 1:26by driddick
				does anyone have a spare spring that goes on the end og the shifter to remove slop... mine is missing
