 by fbernard » 27 Aug 2013 1:00
			That's the engine which was in the cuda when I bought it.
A friend of mine had it built in the USA then shipped here.
It had some detonation (which we later traced to a poor piston choice), which killed two pistons and led to a rebuild by another shop in France.
I don't know whether it's a cast or forged piece, I'll check.
I know it looks like a flaw, the way these indentations are in the metal.
Before taking it apart, I had other suspects. My damper problem from 2010 (the Professional Products damper which separated was on that engine). But that alone breaking a crank, I don't think so.
I found out the French shop had numbered the cylinders 1-2-3-4 on the driver side, and 5-6-7-8 on the passenger side, and I heard they had a hard time starting it the first time... No kidding!
I found out last week that another guy on Moparts had the exact same picture, crank broken right after the front main journal.
I drove to a drag race in  2011 (400 miles), thinking my clutch was not in the best shape (It had been racing for 3 years then). I started noticing a bad vibration by the time I got there (which I attributed to the clutch), and decided to drive back home without racing, to make sure I'd make it with my ailing clutch. Alas, the clutch was not the problem...
That crank drove me home for 400 miles, and the pressure was OK.
I really don't like the oil pressure sender position on the small-block, I'm thinking of someway to install a fitting in the driver side lifter galley, after all the mains get their oil. The current sender position (right above the pump), with a high volume oil pump, just means "pump is rotating".
Only the front main bearing is dead (worn to the copper, but much less than I thought, I believed the block would be worn too there). The #1 rod bearing and journal showed some wear, but nothing extraordinary.
I have yet to do a full blueprint of the parts I have (especially the bores and pistons) before I decide on what to replace. Crank only, rotating assembly, camshaft.
Some parts were a bit mismatched, and need a replacement.
This clearly won't make me a big fan of Eagle. Besides what happened to the clutch, I can't say I'm thrilled by the quality of the rods in this engine.
