Air fuel ratios
I've just finished installing an Innovate wide band air fuel ratio meter and I thought I ought to post the results so I and others who havent tried one yet can learn from it
Ok so drove in this mornin and tried all sorts of heavy engine loads in all gears and different eons, the idle is still pretty good at around 14, high vac part throttle gives over 15, cruising at 70mph gives roughly late 13's , so far so good but when I step on it I see no real change, maybe low 13's, too lean to make real power, I ought to be seeing low to mid 12's ideally.
So this evenin I will be mainly changing metering rods one stage rich, approx 4%, and secondarys two stages rich, approx 8%, idle mixture appears pretty good tho so I'll leave that, it's a piece of piss innit
_________________
Jesus built my hot rod
72 Challenger
65 Barracuda
_________________
72 Challenger
65 Barracuda
