Reason I ask is cos I may be dropping a similar engine into the 65 Barracuda project and wanted to see if they made any worthwhile gains, won't hurt the van to have a bit more torque either
 BTW, I dont have any experience with the Hyper Tech programmer,, I DO have a bunch of exp. with OBD-II scan tools both Uni and Bi-Directional tools.
  BTW, I dont have any experience with the Hyper Tech programmer,, I DO have a bunch of exp. with OBD-II scan tools both Uni and Bi-Directional tools.  I think the only thing you can change is Shift points, timing curves and cooling fan operation. Yes, I think it can be a worthy upgrade if you have the fuel octane available, and if memeory serves me right Dave told me you guys can get a higher octane than here in the states?  We use the RON index and it's from 87-93 octane here in Terry Hut. With the aggressive spark curve you have to use 92-93 octane all the time, this can get costly. With a heavy vehicle like your van, detonation can be a problem,, plus you have a closed exhaust system.(stock), so be resonable with your tune.
Adrian Worman wrote:I think Ive got it sussed out now, that sensor i can see at the top left side of the manifold is the Intake Air Temp, the Engine Coolant Sensor is behind the alternator next to the stat housing, please correct me if I'm wrong
I can't see the bloody thing cos its a van and I can't get my fat head across the top of the motor
