Ok lets start with the reason why they need to be replaced.
I noticed a drop in water levels in the rad and drips of water on the deck from the driver side of the block. I thought it might be the water jacket at the boltings at the exhaust manifolds but I sourced the leak up to one of the plug hole on that side.
The ever fantastic Ade managed to source the correct brass high quality set for me in the uk so I have them with me and ready to do the job this week end.
As Ive never done the job before I need some pointers, some of it I know but any additional help would rock.
Drew told me not to stick my todger in the hole so I wont be doing that this time after the whole..."yeah Wayne, its a ritual and passage of rite that you run the car for 50 mins and then stick your todger in each of the exhaust pipes for exactly 5 mins per pipe, then the will really run well for you as you have mated".....Thanks Dave.....Had a scabby knob for 2 months after that....
Anyway back to work.
Drew and Ade did say to get some rad cleaner and fire it in and run for a wee bit to get all the gunk out of the system before I drain the system take out the bad plug and replace it.
I get the jist of taking out the old ones with a screw driver and spinning it to pull out and cleaning the ope to get rid of any shite left at the area. What should I use to clean the ope with?
Also a few light taps of a hammer on a piece of timber until the rim of the new plug is flush with the engine block plus a small bit of sealer to assist, any recommendations on sealer?
Am I missing anything obvious here guys?
Do I just do the bad plug or do em all with the whole set?
Any help as always is most appreciated.
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
