A pair of Mondello iron heads were included in the deal but I think I'm going to use the Eddys I've got spare.
And the sun was out all day, nearly 20 degrees and I got to thrash my bike all morning, good day all round
Adrian Worman wrote:Hi mates, just picked up this afternoon a 440 block and parts to make a stroker motor, Eagle crank, all bearings, Diamond pistons, K1 Tech ally h-beam rods, Racer Brown cam and roller rocker gear, nice collection of parts, I'll post up all the tech specs during the week and then you can tell me what bits and pieces I need to pay special attention to and if the combination makes sense. Blocks been line bored, decked and bored with a torque plate, and is only 0.004" over stock bore.
Adrian Worman wrote:That answer blew me away a little bit...... I know you get very excited at the thought of engine building and parts selection so I shouldn't be too surprised I guess!
I need to check the bore with a large enough internal bore mike to be dead sure, but the whole motor came to me as a collection of parts and an already machined block, but my friend who the stuff came from said it was honed to just that. The Diamond pistons are custom, they are forged with a dished top to achieve a c.r of 9.7:1 with closed chamber heads, I still have that pair of Eddys that I may utilise here.
The block was decked to 10.700" and is a 68 casting, has an S and HP stamped on the I.d pad and on the oil pan rail.
I'll keep checking stuff out Edd and let you know what else is there, the box of new parts is very deep and it just keeps giving, I found a set of SM lifters and a Profesional Products SFi damper in it this afternoon.
I had a ZZR too, loved it, the BMW S1000R I just traded in was 200 at the rear tyre, the new one I got coming is about 20 more and has a few kilos shaved from it, tips the scales at about 170kg
dave-r wrote:You stuck too many zeros in there Ade. It will be 40 thou over not 4 thou.![]()
If you need to borrow a degree wheel and dial guage I have one I can send you.
Adrian Worman wrote:I found a set of SM lifters and a Profesional Products SFi damper in it this afternoon.
fbernard wrote:Adrian Worman wrote:I found a set of SM lifters and a Profesional Products SFi damper in it this afternoon.
Correction : That is an expensive bedlamp stand, not a damper. Here's what I said about mine in 2010 when the outer ring decided to leave...
viewtopic.php?f=13&t=9189&p=56702&hilit=Professional+Products#p56702
dave-r wrote:The casting is pretty robust. Go for it.
Adrian Worman wrote:Ta for the advice Eddie, i'll ditch the factory iron one on the 440 and use the Xcelerator single plane, think I may add a 4 hole 1" spacer, it doesn't owe me any money so I may as we use it, then find an intake for the 500.
What intake did you use with your mega squirt system?
