I am trying to figure out where the ground strap attaches in that general area. If you can provide a photo of the strap and where it's mounted that would be excellent.
What do you whant to hook up to a ground ? As far as the factory made 70 Challenger i dont know of any ground conektion on the firewall but ofcorse some items were grounded thru the screws that hold them on the firewall !
Understood. I asked because I've seen some older A/ B bodies with ground straps on that side. What about the long ground coming off the blower motor? Where does that terminate? I know it has a rather large terminal ring on the end.
My 70 Challenger had a ground strap from a stud just below the voltage regulator on the bulkhead to the intake manifold on the engine. Don't know if that was standard on all models or what. But I have seen it on many Mopars.
