Hi Edd, the pistons are KB Hyper with a 0.075" step and are + 0.030", fitted with SealedPro file fit rings that were gapped to KB's recommendations, fitted to Sixpack rods and a steel crank, whole assembly has maybe 5 or 600 miles on it and is a s sweet as a nut
The comp ratio now is 10.5:1 with a std Felpro gasket and using the current 452 casting heads.
I saw some special gaskets that lowered comp ratio by 2 points, Hot Rod magazine used them on a BB Mopar build with some success, so I could easily achieve around 8:1 c.r. without much work, that should allow me to run 12 lbs of boost with no fear
I plan on using the Eddy heads that I got a little while back, that will help run higher boost, I plan on using an intercooler too but I don't think the vendor mentioned that, I'll have to check.
The kit thats for sale comes with water injection but I did'nt want to run numbers high enough to warrant using that just for street use.
I just love the idea too mate, I want to push some power out and have a big hit of torque but I still want something very easy to live with and maintain, greedy ain't I
