by fbernard » 03 Oct 2011 9:14
At this exact point in the rebuild, I have a question :
Did you check whether the two #3 bearing halves (the bearings with the thrust surface) were *exactly* aligned?
The #3 mains should be torqued last, and with the crank pushed forward to ensure the bearing halves are aligned.
You should have less than 0.010" of crankshaft end play (between .004 and .007 is normal)
If the bearings are not exactly aligned, the oil film can be wiped off by one bearing half, which end up with the destruction of the crank (a friend of mine has .65" of end play, on an engine with less than 5000 miles).
So, if you haven't done it already, loosen the #3 mains, push the crank forward with a prybar or big screwdriver, and torque the #3 mains while pushing the crank.
Here are the pics :
- In my left hand, a brand new bearing, in my right hand, the same wih 5k miles...
- Look at the end play on this crank.
