Fuel Return and gas cap question
Hello - new to this board, looks like a great one & should have joined years ago... I have a 1970 Challenger R/T 383 4-speed originally from Oregon & I've owned in Seattle, WA area since 1998. Black on Black (originally stripe delete but I added the white bumblebee stripe), build sheet, about 80K orig. Miles and restored over the years.
Needed a little help on fuel system. Car runs great but noticed when I replaced the sending unit years ago I just capped the return line (1/4"). The sending unit has two outlets - one for fuel to carb (upgraded to 3/8"), and the return one (1/4") which I capped. After 11 years of driving it this way I noticed that the cap had cracked and might have been leaking fuel as my mileage went south. I have the flip top gas option and have a replacement Stant non vented cap. Is this right to have it non vented for 1970? Also have the small return line that goes through the trunk that I'm guessing should have a hose to the sending unit return line. Right now I have the short hard line that exits just below the passender trunk floor through the fitting and goes to the fuel filler tube. So my question is do I hook up a return hose (1/4") from sending unit to filler tube? And should my cap be non vented or vented? I suppose with it capped like I have it maybe should have vented cap for expansion. It's run great for all these years so not sure.
Thanks in advance for any info.
Brad
Brad
