It must be less work to do this than machine down the pistons. Explain please
Adrian Worman wrote:http://www.kb-silvolite.com/kb_car/performance.php?action=details&P_id=29
.........cos I got these already fitted and these closed chamber Eddy heads came up cheap. I had a good look at the open chamber Eddy 's and the only difference I can see is the 0.100" relief machined into the head, taking them from 84cc to 88cc. I could check the piston/deck height and consider a thicker head gasket, but I don't really wanna tear the notor apart again, so I'll either save these for a future stroker project or sell 'em on.
Eddie wrote:Adrian Worman wrote:http://www.kb-silvolite.com/kb_car/performance.php?action=details&P_id=29
Yeah, I unnerstan now. It appears as you would have to machine .075 from the quench dome on the piston to fit the closed chamber heads. This would require the engine to be torn down. Using to thick a head gasket would cause severe detonation. It sucks that those pistons you have now, are chamber specific.(Open chambers)
