I know we done this topic many times before, but I want your advice on what I think is my 440 still running too rich. It stinks inside at anything over a very light throtle and stills bogs when I try to accelerate hard. In fact after a spot of full throttle action the smell makes my eyes water. The car drives loveky on a light pedal tho', smooth, torquey, clean idle, sounds real crispy too.
I've recently rebuilt the Eddy Perf 750 and very carefully set the float heights and drop, the choke rod adj and the idle setting. New needles and seats, gaskets and just over 5lbs of fuel pressure. Timing is set to Daves well proven method, got an FBO advance plate and ign module, the electronic dist is set to 20deg initial, 34deg at 3000, no vacuum used and at idle my Mityvac reads about 8" from the fulltime manifold port on the carb.
Just to recap I got 452 heads with very mild work, headers, HP iron intake, Xtreme Energy 284/296, .507.510 lift cam, KB quench pistons, about 10.5 c.r. and a 4 speed with 3.55 gears, nothing radical there.
Got hold of an Eddy jet and rod kit and swapped in a set of 1 stage leaner metering rods, a small improvement was made, have'nt made a jet change yet, need to take the car to a dyno really don't I ?
