Mates, any advice on this please? This morning I took the van, an '04 Ram 5.9 V8, to work and noticed a misfire present at medium throttle about 5 mins after starting and its made a warning light appear on the dash. The light looks like an engine and is yellow, when the engine misfires the light flashes, then it will just stay on permanent.
Misfire appears to get much better, even disappear when its fully warmed up, it will accelerate smoothly and without hesitation, but the light stays on.
I don't have a manual to look at, I assume there is some sort of engine management issue, any ideas?
			 by Adrian Worman » 02 Feb 2011 19:31
 , its got a digital odo Eddie, and its a North American model. If i remember right you told me to do the ign key cycling thing on our '90 Ram van to pick up the fault codes, you then diagnosed it as coolant stream temp sensor, which was spot on. I'll check the harness tommorow and see who I know might have a scanner, think me nephew might have one
