No, not as exciting as it sounds, but I think I've stumbled on a fault in my Edelbrock carb. Went to start car earlier this evening, has'nt been run for 2 months, cranked it, it started fine, then flooded almost instantly, fuel all over the manifold etc. Pulled the air horn off to clean the needle and seats and while looking around for any obvious problems I saw that the weighted  air flap above the secondarys was jammed open. I jiggled it around and found only 30deg of movement from wide open. Removed the secondary boosters to get to the flap and found that the weights were jamming against the carb body. A little twist with my hands was enough to allow the air flap full movement and fall back against the wall of the venturi's. How long it had been like that is anyones guess, but the interesting point is that I've always had a problem with a flat spot the size of the said black hole every time I mash the pedal
 Could I have stumbled on the causre while fixing the fuel leak
