Trep01 wrote:Hi, I'm hooking up the wires in my engine bay (73/Rallye) and have a question regarding the dual resistor on the fire wall.  The resistor has one wire from the coil going into the left side and I know there was another wire on the right side as well but can't seem to locate it.
First things first. Take in the next three points.
A coil has a POSITIVE side and a NEGATIVE side. Make sure you know which is which.
From your ignition switch you should have two wires. One dark blue (RUN) and one brown (START).
The dual ballast obviously has two resistors. They are not the same value so you need to make sure you know which one is the 1/2 ohm and which is the 5 ohm. With the slot on the right and the hole on the left the 1/2 ohm resistor is on the top.
The dark blue switch wire and the blue/yellow wire from the ECU should go to one end of the ballast resistor. The end that is linked together and has a slot on the right.
On the upper left of the resistor (the 1/2 ohm) you should have a wire that goes to the +ve of the coil. Probably blue in colour. Could be green/yellow either.
Now your loose brown wire (from IGN Start) has to go to one end of that coil +ve wire. Either end will do so if it looks like it was on the coil +ve  terminal you can put it back on there.
The lower left side of the ballast (5 ohm) has the green wire from the ECU connected to it.
The black/yellow wire from the ECU goes to the -ve side of the coil.
This is where this grey wire comes in. I think that wire may be for the tach if you have one. Try to see where it goes. If it is the tach then that also needs to connect to the -ve side of the coil.
Hope that helps.
