Fuel tank grommet
There is a leak at the filler tube as it enters the tank the grommet is covered with rubber adhesive which the previous owner had applied as a sealer to contain the leak.
I have a new grommet to go in and went to install it tonight via the manual instructions. Easy Peasy says I.
Remove the 4 screws at the neck/fender, remove the dust cover screws in the trunk floor and draw the filler tube up and out through the fender.
This is impossible as the neck of the filler tube has a large flange as part of its makeup which will only go one way i.e back in to the trunk.
I would think the tank has to be dropped or moved to one side to draw out the filler tube.
Any ideas as to how far this tube runs into the tank ?
Is the new grommet sufficient to contain the fuel or is it installed with a solvent to help seal it?
