Starter for BB's, powermaster lowered its quality?
Postby plum-crazy » 03 Aug 2010 10:10
Hello Guys.
I bought five or six years ago the powermaster XS starter for my 440.
Once I swapped the hemi engine I kept the same starter and works well too.
The friend who bought me my 440 used his stock starter until it finall die and then he dedided to buy a Power Master like mine.
The summit reference is PWM-9513 http://www.summitracing.com/parts/PWM-9513 but they changed the case, instead one piece now has these slim screws fitting both pieces that breaks easily.
There's other references of starters like http://www.summitracing.com/parts/PWM-9523/ or http://www.summitracing.com/parts/PWM-19513/
but at this time I'm not sure about it.
I read the 19513 do not have adjusting block, maybe have more strength than the 9513. Al less the picture is different.
What do you recommend, small but strong?
Thanks.
plum-crazy
Postby dave-r » 03 Aug 2010 11:05
I don't know anyone that uses those. Everyone I know just uses the regular Mopar type mini-starter to replace the heavy stock unit.
Postby drewcrane » 03 Aug 2010 12:02
I installed that same starter a year ago,no problems yet,and i have driven it just about every day now so no problems, :thumbsup:and mine has the adjustment block, i tried it on in 3 different positions and found the way it came from the box was the best position :nod:
drewcrane
Postby plum-crazy » 03 Aug 2010 12:49
dave-r wrote:I don't know anyone that uses those. Everyone I know just uses the regular Mopar type mini-starter to replace the heavy stock unit.
What is the brand?
plum-crazy
Postby dave-r » 03 Aug 2010 13:03
What is the brand?
Mopar. But they are actually made by Denso who make the starters and alternators for most of the motor manufacturers. They are standard on the modern Mopars.
http://www.moparmusclemagazine.com/tech ... index.html
Postby plum-crazy » 03 Aug 2010 14:14
dave-r wrote:
What is the brand?
Do you know if it is available in summit racing?
Thanks
Maybe this one? http://www.summitracing.com/parts/TFF-6084B/
plum-crazy
Postby dave-r » 03 Aug 2010 14:42
Available everywhere I think. It is a very common part. Cheapest is often Ebay.
Postby dave-r » 03 Aug 2010 14:50
Postby jimbob 440 » 03 Aug 2010 20:07
i use power master with the adjustable block on the front of it, so far its the best starter ive ever used for mopar, never struggles at any temp
jimbob 440
Postby plum-crazy » 03 Aug 2010 20:50
jimbob 440 wrote:i use power master with the adjustable block on the front of it, so far its the best starter ive ever used for mopar, never struggles at any temp
Could you confirm the part reference?
Thanks
plum-crazy
Postby jimbob 440 » 03 Aug 2010 21:50
the one i have powermaster xs 9513 your right about the screws it does look a bit weak but ive had no probs and fully rate it, certainly a powerfull starter
jimbob 440
