Hello,
Trying to set the idle mixtue on my 440 (mild - 268 comp cams, 452 heads - stock, Edelbrock 750-1407, 1.6 Harland Roller Rockers, about 10:1 compression, 2300 stall converter, 727, TTI headers,1967 intake-nothing fancy-dual plane). Hooked up a vacuum gauge to the manifold. Timed the car at 34 - 35 at 3,000, and about 14 - 15 at idle. I can get the car to idle in park at about 850 - 900. Idle set screw is very twitchy. Car will almost stall, and with a quarter turn jumps to 1,300. I can get it back at 900 with a little work, and seems to idle pretty smooth.
In trying to read the vacuum at idle, it seems to be around 8-10, but bouncing to much to determine what adjustments to the idle mixture screws really does. At 1,700 or so, vacuum increases, and gauge reads fine. Dropping back down to idle and I can't get a solid reading to make adjustments.
I have the vacuum advance on the distributor attached to the timed port on the carb, just wanted to make sure this is right. The Edelbrock manual said to go the full vacuum port for non-emissions. I know you all are right on this, but just wanted to be certain.
Looked for any vacuum leaks on the intake, and retorqued all bolts to spec, including the carb. Carb is new.
Is there a "basic" setting on these carbs in terms of idle mixture? I read somewhere to bottom out, and open 1.5 turns, is this a good starting point?
Car bogs off idle up to about 1,600 rpm, then runs strong. No black smoke or anything, just not great response. Engine should be better off the line with the set up I have, I would think. I am not mashing the throttle as there are only about 50 miles on the new rebuild. Just doesn't feel as responsive.
Car seems to run hot too, idling for more than 10 to 15 minutes and it gets pretty hot, probably would overhead. May be adding an electric fan in the near future. Maybe the rebuild is still too new, and it will loosen up and cool a little better? Also, will header wraps make any impact on the under-hood temps?
Thanks as always for any help!
- Rich
