After exhausting my limited experience with carburators I am looking for help from the real experts. I have a 73 340 with a Mopar Performance 284-484 cam and automatic transmission. The carburator is an Edlebrock 600 cfm. I have got the car running very smooth with smooth acceleration. My problem is that when the engine has warmed up enough for the choke to kick off the idle rpm has to be set at 1200 and that will drop to about 800 with the car in gear. After driving the car for a few miles and the engine is fully warmed up. the idle rpm will jump to 1500 out of gear but still remain smooth at 800 with the car in gear. I have the vacumn advance hooked up to the manifold port on the carburator.
What is causing the difference in RPM with the car in or out of gear? Carburator settings? timing? vacumn advance? or vacumn leak?
or is this normal for having the larger cam in the car.
Thanks
