I got problems (again) aaaaaargh!!
Mates, please help me with this, as I'm getting really frustrated
and I have to apologise for this long and tedious story, just wanted to give mucho info, here goes:
I got my 440 running nice, booked an mot at my nephews garage, set off from home on what should be a 10 minute drive and made maybe 8mins before the car lost all power, then the motor cut and I ground to a halt at the side of the road.
It would'nt crank so I got my brother to tow me the last mile. When we lifted the bonnet to try and start it we found the battery flat, so we shoved a big booster starter on it and it fired up okay, idled nice and we left it cooling down.
Nephew drove it a half mile to his garage and checked the alternator outpot, it was'nt charging and was traced to a wrongly connected alt feild wire (my fault). I had just installed a Painless wiring loom,new alternator,volt reg, mini starter, relay and battery. I'm sure everythings ok electrically.
So, we take take a quick spin up the street and get 5 or 6 minutes into the journey and it all failed, just like previous
Once back in the workshop we start to investigate, only one thing was ringing any alarm bells, the fuel temp. The fuel line runs up the inner wing in rubber line to a glass filter, then onto the carb, a Performer 800cfm, via a steel and rubber line. The fuel pump is the original, I've bought a Holley 110gph mech unit as a replacement but have'nt fitted it yet.
If we start it up in the workshop it will run lovely for a good 10 minutes, take it out and it stops in no time. The fuel filter sometimes seems to empty itself in a couple of seconds, and the fuel in the carb seems to get very hot. One time the floats stuck and it pissed fuel everywhere.
The intake manifold is iron, a 68 peice, and I think I installed it with heat ris.er passages blocked.
Its an epic isn't it? What do you think then mates?
