We didn't turn the engine over for about a year and when we went to, we only got a click from the starter. The motor ran strong prior to our long drawn out body work.
We placed a fresh battery in, removed and checked the starter and solenoid and they were ok.
Next, we checked the engine/ cylinders to make sure there was no evidence of water/ moisture in the engine.
We found nothing.
We tried a pry bar on the cam bolt and could not get any movement.
Nothing.
We resorted to placing some PV Blaster inside the cylinders and leave it set to see if possibly it'll free something up.
Does anyone have any secrets, tricks or advice on hopefully getting this baby up and running again?
Thanks!
 by cv70chall » 12 Apr 2010 15:19
 1 year in a shop with no water in engine shouldnt cause it to sieze. Yes, if it's still a no-go then it's time to start taking things apart as the ring seal will most likely be compromised. Cast iron factory rings against a cast iron cylinder liner results in very bad things happening to the ring package if seized by corrosion, coolant, water,,ect. Also did you have the battery hooked up to the engine without a suitable earth ground?(This can cause the bearings, rings to seize thru galvanic action  or corrosion)
