Anyone rebuild there stock water pump?
07 Apr 2010 2:02by R/T Rick
				I would like to rebuild my original water pump, does anyone know where to get a reuild kit?
07 Apr 2010 3:08by Jon
				Can't help there you but surely someone here will.
 Just wanted to mention checking the condition of the aluminum housing for pitting. Especially at the thin areas around the ports before setting out.
 I have been through one (SB) timing cover so far from that situation, maybe check it too.
07 Apr 2010 11:44by R/T Rick
				Forgot to mention big block water pump.
07 Apr 2010 12:21by dave-r
				Fit a new one. You can't see it behind the pulley.
07 Apr 2010 12:25by dave-r
07 Apr 2010 14:26by Eddie
				As Dave said, but there are places that will replace the seal and bearing,(rebuild) your numbers matching water pump, the housing shouldn't need any care unless it suffered from cavitation.
www.fdrbp.com
