Will a sloppy timing chain affect performance/driveability?
Today I pulled apart the front of my engine to replace my timing chain and gears because it had the original one with the nylon camshaft gear, to my surprise the gear was in great shape with no cracks, chips, broken teeth, etc... and should probably be framed and sent off to the Smithsonian Institute. lol. What caught my eye was that the chain was so stretched I can almost take it off over the gears without removing them, is this normal for a 440 4 Speed 4.10 gears with only 52k miles? I am also curious if this is the reason for surging at cruising speed. Another thing, whenever I would try to set the timing the mark would bounce all over the place. Will the car run better with a new chain and gears or am I just dreaming? What do you guys recommend for a decent double roller? Any thoughts would be appreciated. Thanks Rick
