dave-r wrote:johannes wrote:The reaction force from the gearmesh forces the intermediate shaft down.
Got an answer for you on that. It is the momentum/weight of the oil in the pump that causes lateral movement of the oil pump shaft (acel/decel).
Hmmmm. Must admit I'm a bit sceptical to your thesis.
Do you mean sideways (out of centre) = latheral movement of the shaft ?
....if so, change the bushing.....
If you mean torsional vibration caused by the spring effect of the steel shaft, and/or the oil itself,.....remember oil is the perfect damper, and even if the shaft is thin,...it's also short, thus relatively stiff towards twisting.
If you mean vertical movement of the shaft, you've lost me...
Chain slack and missing cam shaft thrust button are my main candidates...
Please keep in mind, that the rotating ignition mark is on a damper, thus the outer part (containing the ingnition mark) will to some degree "twist back and forth" relativ the crank....... I have NO numeric values for this movement/twisting,...so they migth be neglectable.......
Hey,....I just want to understand your way of thinking,...not causing troubble....
