burdar wrote:You would easily be able to tell if it was a magnum engine. The intake manifold bolts are straight up and down on a magnum engine...they don't go in at an angle like the old design.
burdar wrote:The best factory LA style 318 heads are the 302's. That is the last three numbers of the part number I think. I assume those are the ones you have.
What year did they switch to the Magnum heads? I thought that was before 93.
airfuelEddie wrote:When all else fails. The LA heads are shaft mounted rockers. The maggies all use a pedastel mount rocker kinda similar to the ford/shivy setups but with a roller trunion instead of a ball socket. As for aftermarket rocker setups the Magnum heads uses standard Chevy ped. mount roller rockers. The shaft rockers are superior in strength and simplicity.
Gotta remember some things about those heads, they were designed for Multi-Point Fuel Injected Truck Engines. The fuel was already atomised at 45 psi before it gets squirted behind the warm intake valve and high velocity airflow aided combustion efficiency with the well designed combustion chambers. The beer barrel manifold has very long tapered swept or tucked runners designed for velocity and intake charge.They can make 410-430 HP stock with a single plane intake and hyd. cam just like their crate engines in the 5.9 Magnum size they used to sell it was stock truck engine with the cam and intake, headers, ect very simple.For above .600 lift I would use a shaft mounted offset intake port head like the Indy or W series MoPar heads. Those heads have much larger intake ports with the requisite volume to make "big power" at much higher RPM's and they have a 'positive' valvetrain but are meant to be used with 48 degree lifter bores and for that the block must change. Hell, I wouldnt use a stock MoPar smallblock for anything over 550 HP anyways. The lifter valley and cylinder bores become an issue. The siamese bore 340 'resto' block is capable however, it has an .180 over bore capability. This has gotten WAY offtopic sorry.Goldenblack440 wrote:wow, thanks for all the good low-down on that. I would like to think that Chrysler in their wisdom would only change a good existing fundamental design if it was well worth doing it. And it sounds like it was, although the teething troubles (burnt ex seats) sounds like a rather fundamental problem! The very fast velocity ports would be great for streetability, but what about at the high revs when you need a lot more flow volume? You shouldn't have to change heads to achieve that. Then again, i suppose when they designed them in these fuel-frugal times, they were not thinking performance like us, more of a more efficient all-rounder.
As outdated as it may be, my upbringing taught a cam and lifters go together for life.
