 by Goldenblack440 » 19 Oct 2009 14:19
			thanks Dave, no need yet, i will hunt around some magazines and the net and see what i come up with. I was under that impression because of what i was told by a camshaft regrinders years ago; i took in an unknown cam and for $50 they gave me an approximate estimation (about 85% accuracy) of its specs with their equipment.  But they said they couldn't give a 100% accurate determination.  Maybe they were too lazy to do it your way, i don't know. But they said a camshaft's unique characteristics is largely determined by the aggressiveness or otherwise, of the ramp, ie, how fast the valve opens, and for what amount during the opening phase, closing speed and at how long etc.
In any case, tonight i took some simple measurements and came up with weird readings.  I took the BCD of a few lobes and got 3.25" +/- 0.01.  Then i took the overall lift from top of lobe to base, and got 4.04 +/- 0.01, to give me a gross lift at the cam lobe of 0.79".  Now, what do i do with this, do i halve that and multiply by the rocker ratio of 1.4?  Or divide that by 1.4.?  In all cases it comes up with a large value for a hydraulic cam, which came out of a cast pistoned standard bore 340 with an ancient 2 barrel on it and standard small valve J heads.
Thanks (BCD = Base Circle Diameter)
