 by Goldenblack440 » 17 Oct 2009 17:26
			Thanks Jon, yes, interesting you say that, because as i was watching him use the expander, i could see how elastic the metal was.  It was amazing watching it expand, then when he released the pressure, you could see it go back down a little.  These were made in Australia, copies yes, but at least they were lovingly copied here, not mass produced in China, like the 3" ones on there now.  The stainless steel they used was probably a marine grade stainless. It was quite malleable. The exhaust fitter said that pipe is just rolled and formed sheet.  The pipe can 'split' along that seam if it is expanded too aggressively or too much.  But luckily these ones didn't.
The reason i am swapping them around is so i can keep the 3" ones for my 440 '71 Challenger.  This will be running twin 3" system. And will be more of a performance motor. This '73 360 is more of a nice tractable street car, so a tiny exhaust restriction at the end will not be noticed.
Not sure what you men by 'offset' but i am hoping they will fit into position the same as the others, in relation to the tailpipe and the valance opening
