Jon wrote: I'll mix it up and see how it works.
 Not a hint of pinging with this ratio. In fact I added 6 gallons of 91 octane to top off the tank at the end of the test session, along with adding 2 degrees advance. Again no detonation.
 I plan to add 2 more degrees initial advance (16) and settle the ratio to about 20% Avgas to 91 Pump Fuel, and see if that's what we can live with.
 Of interest, the idle went down a little bit after mixing the brew. It was very humid today though so I may wait till the weather normalizes before resetting the fuel/air mixture.
 The Oder is quite noticeable. I wonder what the people following me thought. Guess you would have to be involved with aircraft to know the smell.
