ok i did find 2 problems so far , for years since i have been driving this car since 1992 i have had a harmonic vibraton through out the drive train,
well i found the root of the problem it was the power steering pump pully/or shaft was bent it was the origonal unit when i bought the car it never leaked so i went with it, someone must have dropped it or something but it pumped so i could see it when running but never thought it was a problem until i replaced the whole unit and the pully and alot of the vibration is now gone,
what that type of vibration did was shake the crap out of vital components like the carb, and yesterday i noticed a leak in both the float bowls so after tightening the bowls it does run better but i still plan on removing the carb and checking all the parts and replacing the gaskets as well as the power valves,etc.i have been plagued with this vibration for a long time, in fact my first thread on this forum was about this problem ,so i am cautiously optomistic about this car ,but i want to check some other components for loose bolts ,etc.so i will post as soon as i know,
