All,
Here is something strange, as long as the ambient temp stays below 85 degrees, this issue does not show up, car runs great no issues.
Here is one I need everyone's thoughts on, since it is running 95+ every day here in Atlanta (This is important), I was getting cars ready to take to a show. My 340 idles/runs great for 30/45 minutes and then you can feel hear a definitive miss ultimately leading to the car to stop idling and shut down. It starts right up no problems with the miss........we are bewildered as we have checked compression and all cylinders are good (so feel mechanically were ok), the complete fuel system is new, carb, fuel pump (psi is good), timing is spot on and ampmeter on ballast resistor shows 9.5/9.8. New Plug wires, etc...........
So we are continually messing with Holley (New) but I am starting to think that I have some form of electronic issue.....I can't recall the (Don't no name) ignition modulator on firewall fail or have some type pf thermo problem when the temp both engine bay and ambient temp are very hot?
We are going to blow air on it while this is happening to see if this makes a difference.
Anything in the fuel system at the gas tank or inlet line I might be missing?
Remember the car runs great for 30/45 minutes and I never experience this problem is the ambient temp is 85 or below........Electronic, Vacuum or Fuel? What do you guys say?
All help is appreciated, I will let you know when I figure this one out.....
