by Henry (Henry) » 18 Jun 2002 21:34
By Ron Morgan (Cartman) on Monday, June 17, 2002 - 07:46 pm:
ive had the same probs with my 383.
the pressure was im sure around 30-40
but put in a 15w 30w i think,and the pressure has dropped to 10,at 2000rpm-15-20 at 4000,has any one any suggestions as to what to use,and is it best to drain the oil and start again..what is the correct pressures it should roughly be at..
and what is a safe pressure to run at and when to stop using!!
cheers,rgds ron
By Hans (72challenger) on Tuesday, June 18, 2002 - 07:26 pm:
My 340 runs 25psi@900rpm (idle) and about 50-55@3000rpm. I have always heard and listen to the next quote: "for every 1000rpm you need a pressure of 10(00rpm) + 10psi". So 20 for 1000, 30 for 2000, 40 for 3000 and so on. And till now I never noticed anything 'bout my engine. (at least nothing that had to do with oil/pressure)
