mikeandrandi06 wrote:I will have to short block the motor before I can figure deck height right? I need to have the my piston rings gapped and installed first somethig I've never done. Everything is sitting and waiting. My headers give me about 3/4 inch from frame, just a pain to get to oil filter. Can I run the header with the magnum heads? My headers are brand new! Headmans I got lucky to get that would work seeing a header isn't offered for the automatic truck. Was sold a set, tapped and plugged smog ports then they wouldn't go on. Advance auto parts. I went back in mad and asked if they was going to replace my heads, gaskets. refunded my money and gaskets once I found the headers. ON THE OLD MOTOR THAT GOT THE WATER. Is it hard to gap and install rings on new pistons? once I get them done, I think I can short block it. Measure deck height to see about my heads. I got my torque specs, and think I can do the rest. When I install pistons, what cylinder should my piston be all the way up? any to check deck height by turning crank? any, when I install I install balancer I will find top dead center? right?  I found a 1970 dodge motor home with 360 4 barrell running 70000 miles $600 bucks. Waiting on machine shop info. will go look at motor home next week. Sounds like a deal to just buy motor home all works! fridge,ac,stove,etc who knows got horse that needs to go, van that needs to go, 10bulldogs that need to go, and ginseng. Something has to sell and I just might order elderbrock top end? thanks
 The edlelbrock top end would be nice,,especially with the 4.00 bore 360. Early 360 blocks were reportedly cast using 340 block patterns so they can be bored out to the 340's 4.040, what this all means is the 360 block from 1970/71 is  a pretty stout piece. Since it's a motorhome engine does it have the A-727 transmission with it? On the subject of pistons, piston ring gapping and installation. If you have never done it before,, read a engine building manual first. Haynes Chilton,, All Data,,Pro-Link  ect  but I will help you as much as possible. You will need a few tools but some can be 'fashioned' such as a squaring tool, (a piston turned upside down with a ring installed to square the piston ring to be gapped in the cylinder 1/2" to 1" down in the bore). The gap depends on a couple of factors here. The piston manufacturer will have a spec and the ring manufacturer.  What I mean by this is the piston may or may not be a Hyper-uetectic. This type of piston requires special gapping procedures. This piston is designed to expand at the crown or top of the piston and requires a larger gap on the 1st ring to compensate for this expansion. If the gap is to tight the rings will butt and bad things will happen.
 If the piston is a plain cast piston with little silicone alloyed then normal gapping procedures can be followed. Forged pistons require another procedure but most will be gapped at .004 per inch of diameter, so a 4.00" bore will have around a .016 top ring gap. It's very important to understand piston orientation as it goes in the block and on the rod. Some pistons have an offset piston pin, most aftermarket performance pistons dont. If the pins are a press fit onto the piston then the rod small end will have to be heated and the pin pressed thru the piston/rod assembly.
www.kb-silvolite.com has a lot of useful engine building tips.  After gapping the rings, the most inportant part is removing the jagged metal left on the ring after gapping. File this off but dont chamfer the ends of the rings. Then clean all parts with solvent and do a mock-up with a cylinder,,oil on a used bearing, rod&piston installed, completed machined block cleaned and cyl. wall lightly oiled. There are a few ways to do this but heres one without using specialised tooling. Bring it up to TDC,, dial indicator set up on top of piston,(if you have one,,if not you can just use a vernier caliper but it's not as accurate), needle brought up to the highest point just before the piston dwell ends and the piston starts to come back down. This is TDC. Now take a vernier caliper and measure the distance from the top of the block to the top of the piston. This is the piston's deck height.  A vernier caliper and dial indicator can be purchased thru Harbor freight Tools for 30.00 bucks for both, or so. I hope your Dogs&Horse end up at good homes.  Yes,  cast Iron manifolds or exhaust headers can be used on both Maggie and LA plants. They have the same funky exhaust pattern
