Hello, i fired up th3 360 today, hoping for a drive. It was running very rough. I took the aircleaner off and there was wet fuel under the lid and around the top of the carby. This TQ is new. That is, it is fully rebuilt and the guy who does them is a TQ fanatic. Anyway, i started it again without the aircleaner and was able to see it through the windscreen. Within a few seconds i could see fuel bubbling up through the front air tube! I had a look down and it was liquid fuel about 1cm thick in the secondaries.
I could not get through to the fellow who rebuilt it but rang another fellow who is clued up on them. He said one of the floats was sticking up, or, if it had the brass floats, one of them might have a pinhole and was filling with fuel, keeping the inlet valve fully open. I have since pulled it off turned it upside down and poured the fuel out through the top. There was a large amount of rubbish in the fuel! Lots of small gritty looking garbage. I filled it up with fuel through the inlet and poured it out again. Same deal. So i can only assume there is a lot of crud getting through. The filter is on the other side of the pump. I am just about to put in a second filter AFTER the pump. Unfortunately it does not have that very fine mesh inline filter inside the inlet, so i think i should get one of those. I am about to pull the top off the carb and have a look. Dave, or anyone if this has happened to you, what did you do? IS there any pointers you can tell me to prepare me for my excursion into the depths of the TQ fuel bowel? Thanks very much. steve
