i am in the market for new con rods for my 340 build up (+0.040, Forged TRW heavy slugs, 2.02 J heads and small solid cam, expect about 320-350HP).  It is a build on a budget as my expenses are stretched with too many projects at the moment.  There are some cheap conrods on the market - but with good names - SCAT, Eagle, CAT (maybe not so good there) -of course, all made in China, so how good are they? My mechanic said he didn't like H beam because they increase oil windage.  This makes sense to me, he said the groove acts to scoop the oil, thus throwing the balance out and increasing windage, like a spoon.  The oil dripping down from the top end also gets held by the groove he says. He reckons I beam are a better design.  Whats others thoughts?
Also, he reckons these cheaper aftermarket rods have just as cheap rod bolts, even though they look good, he replaces them with ARP bolts, which coincidentally, so does Mancini, with the cheaper Eagle SIR rods.  Maybe they have also experienced returns from rods with the pre-installed bolts...?
Lastly, which steel is better,  5140 or 4340...? 8740 Chrom-moly for the bolts, there are all these advertised.
My budget is around US$300-350 for some aftermarket rods, which is still cheaper than working up some stock rods to that level.  I have some 340 rods, but they are heavy, and with ARP bolts, shotpeening, resizing and rebushing and balancing,, would be expensive.
Any suggestions from people who have been in the same situation. thanks.
		 by Goldenblack440 » 23 May 2009 14:40
 It will blow your budget a bit Steve but only by 75 bucks or so. maybe you can find a set from someone wanting to upgrade or has an extra set??? As far as the 'overseas' rods,, as long as they are carefully checked by a competent machinist,,they should pose no problems and I havent heard of any and have built at least 2 engines of other brands with them and NO failures as of yet and they are drove hard and put away wet!
