gkulland wrote:I have a 1973 with a 340 and am thinking of getting the Edelbrock Performer RPM power package.  It sounds like a good package but I would just like some opinions/testimony to the package.
Your 340 is a good motor. But there are a few things you can do to help it along. I assume since your looking into a 340 engine package that a re-build or engine resto is in order? If so the Ed's package is a good one. There are some that are a bit better though. What are your plans for the engine? racer or street? The 1968 340 is a much better engine due to it's higher comp. ratio and camshaft plus it had a 2.02 intake valve compared to your 1.88 intake. By 1973 the 340 had been 'converted'(some use the word emasculated) to a lower comp. ratio, softer cam, bigger carb. It was in it's last year. I would try and re-create a 1968 340 engine! If you plan on re-building it a new set of pistons with a higher compression height to get the comp. ratio up in the 9:0-10:0 range will give you some torque. Your's was a 'meager' 8:5 to 1 if you were lucky! Then a new fast rate of lift,(Engle, Scott Brown, Comp Cams, Ultra-Dyne, Bullet, Crane, ect many choices here), would also get you more power then the stock juice stick you have now. On to the heads, you would be much better off buying a set of Ed's heads, or Indy/Brocks,(Modified Indy edelbrock castings), or a set of Mopar perf. ones either way you'll have more airflow and better valves, giudes, ports ect or re-work your old castings but be prepared to pay as much for re-conditioning your old heads as a new set of ready to bolt on heads as described from the aftermarket. The intake manifold should be changed to an Edelbrock Performer RPM AIRGAP. This manifold is a jewel. It doesnt give up anything to the single planes and makes more torque/ Power from the start of the RPM band to 6,000+ RPM's,,finish it off with a Thermoquad or Holley/Edelbrock 650/670-770 CFM Carb. Headers would be nice or factory manifolds and duals with free flowing exhaust system 400 H.P and the same torque should be pie.
  I ran a 340 in the  70's and now have a modded 360 in my truck and have usedmany of the parts listed above. They are strong power plants when used with the right COMBINATION of parts, the secret is not to over-cam especially with a low comp. ratio,(stock 1973 ratio), if you DO use your stock ratio, there are some special grind cams that make use of your meager ratio and will still make decent power. Pat runs a 340 so does Jon.
