thank you for the advise i notice your picture that you are using the studd kit on the windage tray can i get away with just the regular oil pan bolts are should i use the studd kit. thank you.
Just a tip, use the "Post Reply" button at the top of the page, instead of the "Post New Topic" one. That way you won't create an entirely new thread when you just want to respond to someone.
I bought a Girdle and it came with an oil pan stud kit because the thickness of the girdle would make the bolts too short and not enough thread contact in the oil pan block rail. It's not necessary in your application Randy
