Stoking question
Postby gkulland » 19 Apr 2009 11:25
Brand new here, quick question. If I stroke out my 340, would I have to get new heads? Also how far should/can i go with the stroke?
gkulland
Postby dave-r » 19 Apr 2009 12:09
No. You will not need new heads unless;
a) you plan to make more HP than the existing heads can provide
b) you need different cc chambers because of difficulty making the compression ratio you want.
But in most cases the stock heads will be OK. Maybe with a little mild porting. But as I say, that boils down to how much power you want to make.
Check out the stroker kits at places like Hughes Engines.
Thanks!
Postby gkulland » 19 Apr 2009 13:31
Much appreciated! I will check out Hughes.
gkulland
